Old Mar 5, 2018 | 11:26 PM
onehundred80
Default Re: A/C blows hot and cold at the same time
it is not moot to me please. if you just had this valve assembly in your hand, please let me know if in fact the angled outlet could be a snap on piece or if it is molded into the assembly and thus there needs to be a different part number. if that is the case, both the chrysler AND Mercedes parts films are wrong?
The angled parts snap on to the straight outlets on the valve which have O-Rings on them.
CLICK
This data sheet has the same numbers on it as my spare valve.
This is the valve.
and this is the hose assembly, the vertical inlets on the valve have O-rings on them and they fit into a fitting on the end of the hose. The fitting clips onto the inlets, you can see the wire clips in the photo.
File Type: pdf
