Old Apr 7, 2018 | 06:52 PM
ala_xfire
Default Re: convertible top locked, intermittent buzzer while driving
Originally Posted by Reb Baron
The test morning was suggesyed by pman, start car ,top is up and locked,windows up.
Then, turn top release handle and pop up the top ,and the windows do not go down.
Continuef tp let the top cycle and on stoe position, the windows csme up and the trunk is unlocked.Yes I lowered the windows before tje top began to cycle. Any thoughts?
The test is to determine if the switch in the windshield is OK. APPEARS FAULTY.
The "D" switch is a signal to connector C1 pin 16 on the PTCM ( Power Top Control Module ) to lower the windows.
It then sends a message to the BCM ( Body Control Module ) to lower both windows via the CAN bus.
This same functionality can be tested by pressing the top down switch 2 times rapidly if the windows are up, or the top up switch rapidly 2 times if the windows are down.
If that test fails, no need looking into the "D" handle switch ( Top Closed Switch )
