Old May 26, 2018 | 11:37 AM
  #77 (permalink)
KeithTexas's Avatar
KeithTexas
Default Re: Manual Top Operation
Originally Posted by piscean3333
@pizzaguy and keithtexas - thank you so much for your fast responses. your information is awesome. So: I tried idle-ing the engine and manually bringing the top up and down 3-4 times. I'm still having a beeping issue. I HAVE NOT yet tried Keith's method to leave the engine off for 2 minutes and start it up again. I will try now. I called Chrysler and they said they have an in house Crossfire specialist that could re calibrate the sensors: i have an appointment Tuesday in the event I can't fix this myself.
One last question: if I try Keith's approach and am still unsuccessful, would disconnecting the battery reset the system or is that a bad idea? I definitely would like to avoid leaving a "blank check" at Chrysler
I don't know about disconnecting the battery. But one thing I didn't mention was that I never touch the uo/down switch. I've had my '05 Roadster for less than a year. At first, I could go through a manual top up or top down process and then push the up/down button and the light would go off and no beeping. But at some point, that stopped working, so I went to the extra step of turning the engine off for two minutes until the up/down button light went off.
You previously mentioned the check engine light coming on? As Pizzaguy said, that's got nothing to do with the top up/top down process. Have you resolved the check engine light question? If you absolutely have to take it to a Chrysler dealer, then maybe you can get some extra diagnostic information for your hard-earned bucks. Good luck!
