Re: AT Tranny stuck in gear
amx1397
it may be low on fluid, but the dealer has the dip stick, your tranny fill cap is sealed. I did have mine stuck in 3 (limp mode) when i was playing with the rear end it would go 1 then 2 then 3 then stay there. jim
What going on from the rear end will cause tranny problem I have a 05 cross want shift out of first added fluid same problem I see lots of fluid on connecter but I add some Same problem helppppp inalI have a rear end problem it makes a rubbing sound when I reverse like something it's grinding it rubbing in something ????????
Reason: Missed out information
