Thread: Rcm
Old Jan 27, 2019 | 10:11 PM
  #40 (permalink)
ambidextrous's Avatar
ambidextrous
Default Re: Rcm
Originally Posted by 1951sms
The other day It turned over for about 3 Seconds. I haven’t gotten it to do that again I was using the key. After that I soldered the relay. Don’t know if it is important or not but the Headlight switch has been hanging down with one recepical empty of one plug. There’s a 10 or 12 pins male connection just hanging behind the switch. It doesn’t fit into the switch empty socket. I haven’t found anywhere it goes?
Okay, it turned over for 3 seconds using the old (original) key, right? When you say it "turned over", do you mean it cranked but didn't start, or did the engine start & run for 3 seconds?
The headlight switch issue is puzzling! Please operate the headlight switch to see if the headlights and running lights operate correctly. The 10 or 12 pin male connector is a puzzle; maybe members more knowledgeable than I (that is, almost all of the Forum members) will explain that.
Don't be discouraged - We'll get this sorted out!
