Old Feb 8, 2019 | 10:42 PM
pizzaguy
Default Re: Took Xfire in and...
Originally Posted by Xenial
Q - Was the engine light on? And What Codes?
A - The Check Engine light was on these are the codes i was told the car diagnosage received.
  1. P0152 O2 Sensor Circuit High Voltage (Bank 2 Sensor 1)
  2. P0153 O2 Sensor Circuit Slow Response (Bank 2 Sensor 1)
  3. P0155 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1)
  4. P0137 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 2)
  5. P0123 Throttle/Petal Position Sensor/Switch A Circuit High Input
  6. P0410 Secondary Air Injection System Malfunction
1,2, 3 - THREE codes from one sensor; the heater circuit is not flowing current, the loop from the sensor is running too high and times AND it's "slow to respond"?
Sounds like a bad sensor, corroded connector or resistive ground to me.
4 - This could be a real O2 code or bad sensor
5 - That one could be in the pedal sending unit or the throttle body.
6 - Ignore this one until you get everything else corrected, it can NOT make the car run poorly.
BUT, since you took the car to a dealer, (see my sigline), I must stop speaking to you, otherwise the vulgarities must flow.
