1951sms
I do use it, I had noticed the the wire coming out of the old Halo was separated at the Halo. only one wire was attached. The newer one was good there but they just cut it to get it out, I used my wire and soldered my end onto it.
You use the key that came with your latest SKREEM,correct? We will assumethat it is the correct one.
You had better say what happens now when you turn the key, you have various things happen in earlier threads, so let’s start over with the current happenings. Any codes set?
