Rcm
Old Jan 28, 2019 | 06:32 AM
  #41 (permalink)
tighed1's Avatar
Default Re: Rcm
Open the rcm.
Turn the key to the ON position.
Check if the engine control relay is engaged.
If not, relay is bad (cooling fan will spin up REALLY fast). I can replace it.
Old Jan 28, 2019 | 08:32 AM
  #42 (permalink)
1951sms's Avatar
Default Re: Rcm
[QUOTE=tighed1;918241]Open the rcm.
[/ The first time I tried it, it was with the replacement key, I haven't tried the old one. After I did what I thought was reprogramming the key. It cranked for about 3 seconds.The instrument panel lit up and all switches work. The cooling fan started running in about 10 seconds. It hasn't cranked over since.I have to check about whether the RCM does anything or not in a while. Have to go get some Propane first,lol ! you guys are the best!!
Old Jan 28, 2019 | 11:30 AM
  #43 (permalink)
1951sms's Avatar
Default Re: Rcm
[QUOTE=1951sms;918243]
Originally Posted by tighed1
Open the rcm.
I have just got my wife to turn the ign switch while I check the relays. None of them click of any movement at all. The cooling fan does come on within a few seconds.
Old Jan 28, 2019 | 12:16 PM
  #44 (permalink)
tighed1's Avatar
Default Re: Rcm
Email me tighed1@hotmail.com
Old Feb 6, 2019 | 01:26 PM
  #45 (permalink)
1951sms's Avatar
Default Re: Rcm
Well I have the RCM back from tighed1. Didn't help, so at least one thing is without question. I have taken apart the old FOB and the recent one bought through the Girl I bought it from. Swapped the Chips back and forth hoping that would help but it didn't.Does the Circuit board inside the FOB make any difference with it starting?
Old Feb 6, 2019 | 03:03 PM
  #46 (permalink)
Default Re: Rcm
None at all.
Old Feb 6, 2019 | 03:29 PM
  #47 (permalink)
1951sms's Avatar
Default Re: Rcm
None at all.
I have a chance to get all the parts I need from a guy. I need to know what to get from him.
Old Feb 6, 2019 | 06:35 PM
  #48 (permalink)
1951sms's Avatar
Default Re: Rcm
None at all.
I Hooked up both my OBD tools, Quick Links OBDII/EOBD CODE READER & ELM 327 INTERFACE V1.5a CODE READER neither one will get into my ECM. What does this tell me?
Old Feb 6, 2019 | 10:21 PM
  #49 (permalink)
Default Re: Rcm
Wow. I just read thru all of this.
I have NO clue what is going on with that car.
Old Feb 6, 2019 | 10:24 PM
  #50 (permalink)
Default Re: Rcm
It may be that the ECM is not powering up. If the ECM powers up, most any OBDII reader should talk to it, I would think so, anyway.
But given all you have done with the car, I'd not know where to start. Sounds like you'd changed RCMs, the battery, a ground cable and did I read that right - you changed the ignition switch assembly? Is everything plugged back in?
Have you measured to see if power is really getting to the ECM when you turn the key on? (Im thinking blown fuse or a connector somehwhere not plugged in all the way).
Old Feb 7, 2019 | 07:58 AM
  #51 (permalink)
1951sms's Avatar
Default Re: Rcm
haven’t checked about voltage going to the ECM. Where do I find the information about searching for the wiring problem? I have found a wire hanging down behind the ignition switch. Two wire connections.
Old Feb 7, 2019 | 09:14 AM
  #52 (permalink)
Default Re: Rcm
The wire hanging behind the ignition switch could be the wire that goes from the halo that surrounds the ignition key hole that goes to th SKREEM. If this is it then the car will not start.
A photo of the SKREEM.
The SKREEM and how it looks behind the dash panel. CLICK
Old Feb 7, 2019 | 09:52 AM
  #53 (permalink)
Default Re: Rcm
1) haven’t checked about voltage going to the ECM. Where do I find the information about searching for the wiring problem?
2) I have found a wire hanging down behind the ignition switch. Two wire connections.
1) The service manual, you can download it from here on the forum.
2) Like Dave said, that is possibly the wires to the ring - find out where it goes, if it goes to the ring around the key, then plug the loose end into the connector on the SKREEM, your nightmare may be over at that point.
I also asked if you changed the ignition switch, but you didn't answer. If you are not going to READ my posts and ANSWER my questions, you are beyond help. I cannot diagnose your car - I am not standing next to it, YOU ARE. YOU are my eyes and ears. I am tired of saying this over and over, seems like, in the past year, everyone I try to help half-way reads my posts and responds to only part of what I ask. THIS is why I don't post here as much as I once did, life is too short for this.
Old Feb 7, 2019 | 10:02 AM
  #54 (permalink)
1951sms's Avatar
Default Re: Rcm
It’s not to same color wires. There’s not a interior light wire is it? Does that halo fit only one way? The wires going to it connect to the top of the switch.
Old Feb 7, 2019 | 11:04 AM
  #55 (permalink)
Default Re: Rcm
What color wires are they?
Old Feb 7, 2019 | 02:52 PM
  #56 (permalink)
1951sms's Avatar
Default Re: Rcm
Orange with yellow tracer and Brown. I would love to be able to speak with someone on my problem. If it’s possible send me a private message with your number. Thanks
Old Feb 21, 2019 | 09:36 AM
  #57 (permalink)
1951sms's Avatar
Default Re: Rcm
I'm sorry about not responding fully on this but here goes : I have replaced the Ignition Switch,SKEEM with Halo, ECM all from a running car. Didn't do anything different. I have tested the OBDII connection and the pin 16 was good. pin 4 Resistance was good, Put a new brake light switch in it, it was bad,Checked Fuse 14 and it has good voltage.
Old Feb 21, 2019 | 09:46 AM
  #58 (permalink)
Default Re: Rcm
You must use the key from the car that was running, your old key is of no use.
Old Feb 21, 2019 | 09:49 AM
  #59 (permalink)
1951sms's Avatar
Default Re: Rcm
I do use it, I had noticed the the wire coming out of the old Halo was separated at the Halo. only one wire was attached. The newer one was good there but they just cut it to get it out, I used my wire and soldered my end onto it.
Old Feb 21, 2019 | 10:03 AM
  #60 (permalink)
Default Re: Rcm
You use the key that came with your latest SKREEM,correct? We will assumethat it is the correct one.
You had better say what happens now when you turn the key, you have various things happen in earlier threads, so let’s start over with the current happenings. Any codes set?
