1951sms
1) haven’t checked about voltage going to the ECM. Where do I find the information about searching for the wiring problem?
2) I have found a wire hanging down behind the ignition switch. Two wire connections.
1) The service manual, you can download it from here on the forum.
2) Like Dave said, that is possibly the wires to the ring - find out where it goes, if it goes to the ring around the key, then plug the loose end into the connector on the SKREEM, your nightmare may be over at that point.
I also asked if you changed the ignition switch, but you didn't answer. If you are not going to READ my posts and ANSWER my questions, you are beyond help. I cannot diagnose your car - I am not standing next to it, YOU ARE. YOU are my eyes and ears. I am tired of saying this over and over, seems like, in the past year, everyone I try to help half-way reads my posts and responds to only part of what I ask. THIS is why I don't post here as much as I once did, life is too short for this.
