Old Feb 21, 2019 | 03:08 PM
  #214 (permalink)
turbomar's Avatar
turbomar
Default Re: C32 Brake upgrade
Originally Posted by DHS
PROBLEM!!! Last night got a big pot hole in the rain, tire did not deflate but today it was flat! The rim bent on the inside so I could not see it last night. So I just pulled that SRT wheel and found the dent. Figured I would just put the NA wheel on until I can fix/replace the front rim. The front NA wheel will not clear the caliper with the 10mm hub centric spacer! When I torked the lugs the wheel just touches the caliper, it looks like it will need a 12mm to clear a stock NA wheel. So the SRT wheel provides more clearance than the NA. So anyone going to the CLK500 sport caliper with the 345mm disk will need wider hub centric spacer if you plan on going with a NA wheel. Remember the SRT wheel cleared with a 5mm spacer, if you can find a hub centric that thin, BUMMER!
up until last night the big brake setup was doing great, I was very happy with the braking action I had.
looking for a SRT front wheel
Dan
u need 20mm spacer 2 accommodate d na wheel
