Okay just got the valve cover leaks fixed after the car was sitting for about a year before that it was running fine. Now I have this new problem. Ragin Cajun reported the exact same symptoms back in 2015 in the attached thread but he never gave a solution.
Symptoms: After car sits for awhile it will start with no codes or lights on the dash. It appears to be running fine. Once I try to drive it and get over 30mph the speedo goes to zero, brake wear indicator turns on, BAS/ESP light comes on, brake light comes on, ABS light comes on. My cheap OBD BT code reader detects nothing when I read the codes even though all the lights are on. If I put the car in park I can no longer put it in drive without using the cheater door. After I turn the car off it will no longer crank at all. Turning the key to the crank position does nothing. Does anyone have any ideas?
Tried so far:
Reflowed the solder on the RCM
Link to previous thread from Ragin Cajun:
https://www.crossfireforum.org/forum...tuck-park.html
Thanks, Chris
