Old Jun 18, 2019 | 01:24 PM
pizzaguy
Default Re: Check Engine Light ON...... any ideas?
Originally Posted by zip439
However, if you will use the search box at the upper right corner of this forum you will will find that the "Sticky Key Fix" is a one time repair and will cost you $ zero
I'd like to suggest NOT using that box.
I actually find it way easier to type my problem into Google like this: "Chrysler Crossfire thing that is broke" and look for the forum links - seems to work better than the forum search:
This has worked well for me, in fact, when someone on Facebook asks a question, I usually use this techique to find things. Like above, "Trunk lid jammed" is probably the best one, but the others can be helpful, too.
