Old Sep 9, 2019 | 01:20 PM
pizzaguy
Default Re: Radio and anti tow module
Originally Posted by BrianP
Thanks, i found the siren under the cowl, what i was looking for is the module that trigger it. As for the radio, its seems turning it off manually keeps it off. I will live with that.
Thanks
If the radio is doing what you describe, I'd think the switched A+ fuse for hte radio is blown, but the battery fuse for the radio is NOT blown. That is, it has lost it's ignition sense.
Check the box under the hood, driver's side. THere are TWO fuses for the radio: 1 is battery feed, 1 is accessory feed.
