Old Sep 21, 2019 | 07:50 PM
  #45 (permalink)
onehundred80
Default Re: Beeping above 75 mph
Originally Posted by Toolman
Inchworm it was a pleasure meeting and talking with you today. Having tested the 75 mph alarm I certainly understand how it can be repeatedly annoying when passing on the turnpike.
Wadsworth, I tested the procedure on the 06 coupe I purchased last month. It had a tire pressure light on, but I didn't bother with it because I was having new tires, and the Shrader sensors I purchased, installed at the end of the month. To my surprise the original sensors on the 06 had some battery life in them and the car relearned them.
I suggested to Inchworm we try it on his car, but I could see with the DRBIII that no signal was received by the car when the relearn magnet was applied to the sensors. My opinion is the incorrect replacement sensors were installed.
If I recall correctly some of the OEM sensors required a magnet to set them and some did not.
The universal Schrader sensors #2028? do not use a magnet, again if my memory is correct.
