onehundred80
If I recall correctly some of the OEM sensors required a magnet to set them and some did not.
The universal Schrader sensors #2028? do not use a magnet, again if my memory is correct.
I don't know about the 2028, but checking the
schradersensors.com website for the 20028, which I show above, it does use a magnet. I didn't clearly describe it above, but following the DRBIII screen prompts I had to use the relearn magnet on each sensor to have the 06 car chassis relearn the sensors which are oem originals.
I do recall reading that some newer sensors can clone original sensors. That requires equipment to read the original sensor and then program it to have the same code as the original. I don't know what vehicle sensors that would work with.
