Old Sep 26, 2019 | 05:46 AM
  #57 (permalink)
Toolman's Avatar
Toolman
Default Re: Beeping above 75 mph
Originally Posted by Wadsworth
Can you check using Mercedes or is that a program purchased separately?
I only purchased the Chrysler program. A second brand was $60.
I also own the iCarsoft Auto M900 V2.0 Mercedes-Benz Diagnostic Scan Tool. It works with the Crossfire, but I was expecting more comparing it to the DRBIII and Starscan. I'm impressed with a few areas with the Foxwell like the convertible top readings which certainly would help those with tops not working. I'm going to trigger an air bag fault to see if it will clear it, and as mentioned above will test the tire sensor relearn procedure.
