Old Oct 1, 2019 | 03:36 PM
  #57 (permalink)
zip439's Avatar
zip439
Default Re: DIY Rear Cambers
Originally Posted by Sussudio
Also do you guys know if this is what I need for the front adjustment? https://www.ebay.com/itm/For-2004-20...-/392415990263
Picture doesn't show the cut flute in the threads. The adjustable bolts for the front should have a flute cut into the threaded end.
Try searching for Febi 202 330 01 18. You should find them for less $. You will need at the minimum one bolt for each side of the vehicle, but four bolts in total would be preferred.
