Old Jan 12, 2020 | 04:19 PM
  #49 (permalink)
ArtS's Avatar
ArtS
Default Re: DRB III Emulator?
'glad to see you got this working for you.
So now, we have at least 2 Crossfires in S.C. with a working TPMS !
Art
Thanks a lot for the PDF instructions that laid out the TPMS Sensor Relearn process. Finally got a nice day today (nearly 70 deg F here after storm front went thru last night). Executed the Sensor Relearn process and no more TPMS light!
Couple of things I did learn along the way:
1) If the car battery doesn't have sufficient charge, the DRB3 Emulator software will not work. The 1st attempt I made to scan & re-learn the sensor IDs failed because an error message popped up on the laptop stating the car battery did not have sufficient charge.
2) The Autel 501 Scanner did not allow me to select a 4-wheel scan instead of a 5-wheel scan for the Crossfire. I just scanned the 4 wheel sensors & then deleted the 5th wheel sensor. Don't know if I would recommend the purchase of this specific scan tool to anyone because of this anomaly. I'll perform a software update on the scanner later on & see if this gets resolved.
3) The 2 new TPMS wheel sensors read exactly the same pressure. The remaining OEM sensors read different and may be an indication of pending failure. After all, it has been 12-13 years!!
Anyway, thanks again for the PDF instructions.
Later,
