Old Jan 28, 2020 | 08:49 AM
  #38 (permalink)
pizzaguy
Default Re: I hacked the Skreem, the Skreemulator
Originally Posted by Viper-666
Yes my goal is to make a generic skreem, so the problem with the not available key fobs were be also solved. I thing I will go a way to unlock the car with RIFD or NFC Tags. If your skreem already works, you can read out from that 4000 codes (if your skreem has already so much) my module will make with a trick 8000 codes of them. No PCM programming necessary. You can repeat this so long until your skreem has no more codes.
If your skreem is broken you became from me 8000 codes but your PCM had to be programmed that it will work with this codes. If you have used all 8000 codes you will have two options:
First: Buy an other EEPROM from me with 8000 codes (or buy it at one with my Skreemulator).
Second: Reprogram your PCM and reset my SKreemulator, than you can use the 8000 codes again. This can be repeated infinitely.
How did you arrive at the conclusion that there are a limited number of starts in the system? This contradicts what is in the student manual.
I find it hard to believe that a manufacturer designed a car with only a certain number of starts.
