Old Feb 11, 2020 | 07:51 PM
  #59 (permalink)
lotsofspareparts's Avatar
lotsofspareparts
Default Re: Worlds Cheapest V8 Swap
Originally Posted by monaderio
One more thing, how are going to weld the internal tubing? Or are you going to leave it as is?
You don't have to weld the internal tubing, all of the internal tubing is slip fit. That's what makes mating the manifolds so easy to do.
You cut them open carefully without cutting through the internal tubing. Once the cut in the heat shield goes all the way around...… it falls apart.
Jared
