Old Feb 27, 2020 | 08:41 PM
pizzaguy
Default Re: Cooling fans won't stop running with car turned off
Originally Posted by Merlincat
Hi, new to this forum.
I have an 04 Crossfire. The cooling fans weren't turning on, at low or high speed, so I replaced the 50 amp fuse. Now the the fans are running full blast and wont turn off even when the car is off, unless I unplug the battery or the radiator fan control module. I'm thinking to replace the relay fan control module, but wondering if anyone has any other ideas of what the problem might be? I read something about the cooling fan controller, but I haven't been able to locate it under the hood or figure out how it fits into the circuit. Feedback much appreciated!
*also no codes are being shown by OBD
thanks so much!
Has to be a bad fan module. Follow the wires from the fan motor over to the module on the fender. THAT is the module you need.
