Old Feb 27, 2020 | 08:43 PM
pizzaguy
Default Re: Cooling fans won't stop running with car turned off
Originally Posted by don cobb
My radiator cooling fan will not come on. I replaced the fan control module today and nothing changed! Looking for heip!
If the engine is not warmed up past 200F, the fan wont run unless you turn the A/C on, then it should run at a low speed. If it simply wont run, it has to be:
Bad fan motor
Bad Fan controller module
Blown 50A fuse to controller
