Old Mar 2, 2020 | 08:36 AM
pizzaguy
Default Re: No start cracks 3 times fuse 37 keeps blowing out
Originally Posted by Ozzie007
I'm also having the fuse 37 keeps blowing every time I replace it straight away the manual say fuse 37 is for Circulating Air, Instrument Cluster, Radio Frequency Remote Control, Residual Engine Heat Utilization
also I don't know if this is related or if the car is like that when I try and start the car i get no instrument lights symbols on the dashboard they do not come on at all when trying to start the car.
I need your help to find a place in uk London area to fix the skreem module or maybe this another issue and also any of you guys have an idea why the fuse 37 keeps blowing straight away everytime the fuse is changed.
Fuse 37 feeds the SKREEM, your car either has a bad SKREEM or something ELSE is blowing that fuse and disabling the SKREEM. (Fuse 37 is also one of the feeds to the instrument panel - which explains some/all of the other symptoms.)
The service manual is fairly accurate - what needs to happen here is for SOMEONE to grab the service manual, and use it to intelligently isolate the cause of the blowing fuse.
Good luck with this, I doubt the 'mechanics' in the UK are any better than those over here, when it comes to diagnosing a simple blown fuse.
ANYONE chasing this and NOT referring to the diagrams in the service manual is wasting their time.
