90 degree banjo fitting allows use of stock line.
Progress note: got the banjo fitting and bolt today, needed to trim the bolt, but with the trim and copper crush washers it fit. Put on the SS line and it works fine! Here is the photo. Will give the part numbers when I do the MEGA update after all is done with a test drive. Probably this Saturday!
Was there any reason why you
DID NOT install C32 AMG
caliper backing plates (splash guards)? I can't believe I never thought about it before.
