Thread: Fluid leak
Old Jun 22, 2020 | 10:59 AM
onehundred80
Default Re: Fluid leak
Originally Posted by kakenetit2
You don't need to pull the pan if you don't want to. Just the connector and add in about a quart of ATF. That kit link I sent you is perfect for that.
You add the amount if transmission fluid that is required to bring the fluid level up to where it should be, no more no less.
