mlinster
here is a picture of the pulse module. When I When I close the relay on the left nothing happens. When I When I close the relay on the right there is a fairly loud click under the engine, which I assume might be the starter. It almost sounds like the starter is trying to engage but is locked up. Any ideas?
I'd assume you are hearing the solenoid on the starter engage. Sounds like the solenoid or starter is bad - a rare failure but it can happen.
Just one thing, close that relay and measure voltage at the starter - yes AT THE STARTER. If it is at least 10-11 volts, replace the starter.
If it is very low, you have a cable or battery or connection issue.
