onehundred80
Water in the oil shows up as a white emulsified slimy deposit on of the underside of the oil filler cap.
That'll be a negative then chief.
ZERACER
My guess is the valve covers leaking and it is burning on top of the engine and dripping into the plastic cover under the engine. Check the top of the engine and drop that cover underneath and see what it looks like. Inexpensive place to start.
Replaced valve cover gaskets on both sides a few months ago - they look nice and clean!
philosophico
These motors dont really burn oil, leak oil yes. I think you have a bad valve cover oil leak. I currently have one and was loosing as much oil as you and was like I know im not burning that much oil as it would be a smoke show out the tail pipes. Turns out the driver side valve cover was leaking badly from the front where the power steering pump is and running down and under the oil pan. I didnt have any leaks because it was sticking to the bottom of the oil pan and when moving would get blowed through the underside of the car.
If I were you, I'd do a through check under the car torwards the front and side of the engine.
Used to leak oil that'd fall on my exhaust manifolds and burn, but I recently just replaced my gaskets and everything has been nice and clean since...
