Still burning oil - Desperate for help
Old Aug 7, 2020 | 03:50 PM
BeanMan's Avatar
Default Re: Still burning oil - Desperate for help
Originally Posted by zip439
You really need to get that car up in the air, drop the plastic shield under the engine and take a good look from the bottom. It is not uncommon for a leak to develop near or at the rear seal and anything from above will be seen from the bottom. That catalytic converter going bad is also a piece of the puzzle.
I'll try that. I see your reply on 'Bad Oil Leak'
Originally Posted by joeyav
Hello,
Here is an old trick from my hot rod days. Take your vehicle out to a highway or a road to get the car up to 60-70MPH, then take your foot off the gas and let the car coast for about 10-15 seconds, then give it a lot of gas. If you have a problem with rings or better yet, valve seals, you will get a pretty good puff or cloud of smoke. When you take your foot off the gas the engine goes into high vacuum and will collect oil in the combustion chamber.
Best of luck!
Will try that after I inspect the bottom
Originally Posted by ZERACER
Was that perhaps before catalytic converters? The Crossfire has four.
Front right I assume. May be a seal/gasket or something as well due to how much it pollutes my cabin.
Old Aug 9, 2020 | 01:48 PM
mikemadeit94's Avatar
I know you said the valve covers are done, but did you put gasket maker on the other two smaller covers on top the valve covers? I just had to it as well..
Old Aug 9, 2020 | 04:48 PM
BeanMan's Avatar
Yes, crankcase is good.
KelloggKid
20
Oct 13, 2011 10:48 PM
jrizz513
Aug 24, 2011 10:17 AM
frenchcrossfire
U.K.
Jul 26, 2011 08:34 PM
frenchcrossfire
Jul 26, 2011 01:20 PM
nox1s
Feb 11, 2008 09:52 PM
