Old Oct 10, 2020 | 11:48 AM
pizzaguy
Default Re: Turns over but doesn't start
Originally Posted by Mike_man458
yea I changed both crankshaft position sensor and camshaft position sensor an still nothing I looked up on YouTube that wen u put the key in an try to start it it will turn over but want start then I'll do it again an it will do it again now the third time I try to start it there's nothing like it want even turn over people are saying something about a skreem module well I took it out an waiting till I have enough money saved then I'll buy a new one it's like $730
No, it does not cost $730 because you cant get them anymore. What you CAN do, is yank the ECU, SKREEM and pack them with a key and send it all off. The ECU can be set up to ignore the SKREEM. SOS Diagnostics and Needswings can both do the work.
Contact each and see what they charge. Perhaps it IS $700 but I was thinking the "SKREEM Bypass" was less expensive than that. Contact the two companies, ask, don't go by what others say, even me.
