Old Oct 12, 2020 | 08:56 PM
Ronman's Avatar
Ronman
Default Re: replacing the hatch lift support
Crossfire Coupe Hatch Struts
I just installed these earlier this week. Connection on cylinder end was "cocked" a little (compared to OEM version), but cylinder installed & worked fine.
The OEM struts are made by Stabilus/Sachs, here is the aftermarket version. https://www.rockauto.com/en/moreinfo...422548&jsn=431 The only issue with all the aftermarket lift supports is they don't have a dampening effect when the hatch is lifted like the originals so the hatch will shake a lot when opened if you do not guide it.
