pjpsrt
I have been trying to get the micropod going for quite awhile.
i have a windows 7 -32bit ready
some of the info about loading the programs indicate you allow updates
others say don't allow it to communicate at all.
which is it? turn off the wifi from get go? or get to the adobe and java and update.
is witech ever allowed to communicate?
i have loaded and wiped the laptop several times now.
thanks in advance.
phil
There might be an issue if the micropod clone you bought is not compatible. Here are the detailed instructions and I got it to work on the very first time:
How to install DRBIII Emulator for Micropod 2 on Windows 7 Pro 32-bit | OBDII365.com Official Blog
You will need an internet connection to update and install. You disable the internet at the very end just like it says. Then witech is never allowed to connect to the internet once everything is installed.
