Old Oct 15, 2020 | 02:55 PM
  #83 (permalink)
dedwards0323
Default Re: DRB III Emulator?
Originally Posted by Ronman
There might be an issue if the micropod clone you bought is not compatible. Here are the detailed instructions and I got it to work on the very first time:
How to install DRBIII Emulator for Micropod 2 on Windows 7 Pro 32-bit | OBDII365.com Official Blog
You will need an internet connection to update and install. You disable the internet at the very end just like it says. Then witech is never allowed to connect to the internet once everything is installed.
Like Ronman identified in the above quote, when I followed this setup exactly as written, everything worked fine for me & still does. I made a PDF file & saved this instruction on my laptop.
