Old Nov 4, 2020 | 09:33 AM
pizzaguy
Default Re: (1st Post) Bought 2007 Crossfire
Originally Posted by Romad
Took my "beast" for it's first night ride to check out the headlights. The left low beam is aimed downward at about 45 deg to the left. Couple of cars had given me high beam flickers. I guess beam was blinding them. I watched a YouBoob video to see how to replace bulbs orientation. Looks like it going to be tight fit and have to unbolt some things to be able to get at it.
No, you need not unbolt anything. If the beam is 45degrees down from strait ahead, someone has placed the bulb improperly. It is easy to screw up, I only replace bulbs with the lights on, about 5 feet from a garage door - makes it easy to seat them properly.
Strange that yesterday my steering was fine and now it seems to want to wander a little and when braking it's pulls slightly to the left. Guess I might have to pull the front wheels and bleed the brake lines to see if I get a little air out of the line. Also will check pad condition on both tires.
It was fine yesterday? Sounds like tire pressure to me.
