Jack G
With regard to seat issue, If it is either a motor or switch related problem the only way to resolve it looks like I will have to remove the seat. Is this correct?
Removing the seat doesn't look too difficult. However, the seat is all the way to the rear most position which might make accessing the 2 rear screws very difficult.
Have you had a peak under the seat to see if the harness is plugged in
I know it’s pretty obvious but what if...
