XfFreChris
So if I have the existing board( damaged ,but rf chip is there, I can have that put on a new fob, with my existing physical key, and should work?
Viper-666
That would't work because in the skreem are the rf codes who are on the rf part is stored prestored so no other original rf will open your car or can be teached to work on your skreem.
Viper, Chris, pretty sure Chris is right. IF you use the
OEM FOB key RFID chip (
paired with the OEM Veh SKREEM), in a replacement FOB circuit board and case, that SHOULD work to start/lock/unlock/alarm the car as normal.
