Wheel speed sensor issue (not sure that sets a code the '1100 sees) or maybe traction control relay on the RCM has failed (again, not sure that sets a code).
The fact you are driving the car in Ohio in winter tells me salt/corrosion is a suspect. Do either my mod or James' mod (it will cost you around $20 and an hour of your time) and drive the car maybe three times, see if it clears. If so, you had a ground return issue somewhere.
Go here:
https://www.crossfireforum.org/forum...le-engine.html
