Old Feb 25, 2021 | 07:58 PM
pizzaguy
Default Re: Top and spoiler not working
Originally Posted by kztkadir
When the service checked again, they said there was no problem with hydraulic pump. They said it was burned due to an electrical fault in the cables.(maybe water..) This damaged the top module of my car. I think I'll have to buy a new top module. They said that when the new top module is fitted it will probably work..
Water damaged electronics can be very hard to repair. If wiring has corrosion from water, getting connectors cleaned effectively can be very hard to do.
I also doubt the top module is damaged, unless the trunk area has been under water.
Is there any sign of water under the trip pieces? If you raise the lid and look in the wheel wells, is there any sign of water in there like: Corrosion, rust, discoloring of the harnesses, etc.?
For help with figuring out what is going on, try this thread:
https://www.crossfireforum.org/forum...p-sensors.html
Also, this one:
https://www.crossfireforum.org/forum...formation.html
How to manually operate the top:
https://www.crossfireforum.org/forum...operation.html
This man is an expert on the Crossfire and other tops:
https://www.youtube.com/channel/UC42...OglbgpBvTjXpUU
