Old Mar 2, 2021 | 08:50 AM
pizzaguy
Default Re: Help "flywheel" needed...
Originally Posted by chriscat32
The clutch pedal going to the floor is not related to a bad flywheel. If it worked before sitting for 3 months, you probably need to bleed the slave cylinder or look for a leak.
If your flywheel and clutch is bad you certainly would have known it before you parked it.
Same goes for shops that tell you that you need all sorts of front end and steering parts when you get new tires. If the car handled well and tires wore reasonably well on the old tires - your car is fine.
