X1 GSW
Fyi - I removed fuses 5 & 8, carried out a software reset (I have the Nav oem unit), which I did by pressing the DTM button and numbers 1 and 3, inserted the radio code and hey presto! Whatever gremlin was in the system is now away (at least for now!). The bonus is I’ve now been able to pair my iPhone with the Bluetooth unit that the previous owner had installed to the oem unit (by Becker Sound LLC in USA), so happy days!
Curious if you performed the software reset with the fuses pulled? Is the software reset even possible with the fuses pulled? If the fuses were re-inserted before the software reset, did you have the key in the ACC position so the leg with Fuse #5 was powered up? Or did you have the key in the ON position which powered up legs with Fuses #5,& #23? Just wanting to follow your efforts when dealing with the same issue with my car. And congrats on getting your issue resolved.
