Old Mar 19, 2021 | 07:31 PM
pizzaguy
Default Re: BAS ESP light stayes on.
Originally Posted by Shaines242
I have a similar issues with warning lights. I've been searching the forum but have not found any posts with the conditions I'm experiencing.
I have an 05 Base Roadster, 6 speed.
My BAS ESP light is illuminated, along with the ABS and BRAKE lights on the far right. On the far left side, the Check Engine and Brake Wear Indicator lights are illuminated. The speedometer has stopped functioning. The spoiler light is blinking, and the spoiler remains deployed. Other than those few items, everything else seems to functioning correctly.
My first thought: The traction control relay on the RCM is bad, or the solder connection on the edge of the RCM that fees B+ to the traction control system is fractured/bad. If you had an automatic, it would be more obvious, because the car also would not shift from PARK.
Yank the RCM and send it to DJ in Arizona ($50-60) for rebuild or order a new one ($150-200) from FCP Euro, etc.
This thread shows you how to remove the RCM (No tools needed), the repairs described concentrate on OTHER failure modes of the RCM...
https://www.crossfireforum.org/forum...-no-start.html
