Yea, but ours does not work that way, no ground is needed at the motor, the BCM switches ground to the motor to operate it.
The Park switch in the motor has one pole to 12 volts, the other pole goes to the PARK input on the BCM.
As is so often the case, our cars are not set up like 'normal' cars....
