Wiper Malfunction - I'm Stumped
Old Jul 31, 2021 | 12:51 PM
Default Re: Wiper Malfunction - I'm Stumped
search repairs and send Matt a text he does not answer his phone and yes he does travel he is in miami ,,and is a big help on my v8 crossfires . jim
Old Jul 31, 2021 | 04:20 PM
Egyorko's Avatar
Thanks, per your suggestion some time ago I have texted multiple times and he has not gotten back in touch.
Old Jul 31, 2021 | 10:18 PM
I will call him ,,get back to u in a few days btw where are u , i am in indialanric which is 50 miles east of orlando next to the ocean
Old Aug 1, 2021 | 03:26 PM
Egyorko's Avatar
Hi Jim, I’m in Indialantic too. See PM I just sent.
Old Aug 2, 2021 | 11:09 AM
Doc78's Avatar
Hello,
I found this on page 8R-26 in the service manual(it is available for download on this forum). For wipers always on. I did not see where you measured a voltage at the wiper switch Mux on your well written troubleshooting word doc. I hope this helps!
Turn the ignition off.
Disconnect the Multi-Function Switch harness connector.
Note: Check connectors - Clean/repair as necessary.
Turn the ignition on.
Measure the voltage of the Wiper Switch Mux circuit at cavity 7 of the
Is voltage present?
Yes >> Repair the Wiper Switch Mux circuit for a short to voltage.
Perform BODY VERIFICATION TEST.
No >> Replace the Multi-Function Switch. (Refer to 8 - ELECTRICAL/
LAMPS/LIGHTING - EXTERIOR/MULTI-FUNCTION
SWITCH - REMOVAL).
Old Aug 7, 2021 | 08:32 PM
Egyorko's Avatar
Problem solved! No longer stumped.
I put WAY too much thinking into this. As it turns out the grey shroud over the wiper motor connector (that plugs in to the front of the BCM) slides to lock it in place. It was positioned such that the connector would not fully seat into the BCM - just enough so that the power and ground pins were connected but the wiper motor sense (park switch) was not. That is why it stopped in random positions, as if the park switch wasn't functional. All I had to do was slide the shroud back, fully seat the connector and VOILA - perfect wiper operation.
Thanks again to everyone who worked here to help me out. Feel kinda dumb about it, but after a few months of shaking my head I'm just glad it's working now!
Old Aug 7, 2021 | 08:45 PM
I had that connector off last week, ittakes a bit of effort to move it. Good work.
Old Aug 7, 2021 | 10:57 PM
Ronman's Avatar
We really appreciate that you let us know what happened. Too many other people just post and never let us if it was resolved or anything for that matter. Good job and congrats!
Tirepitstop
Oct 6, 2018 08:37 PM
Vyse
Sep 15, 2017 04:48 PM
Clement
Sep 5, 2011 04:44 PM
DandyDon
Jun 25, 2011 08:33 AM
typhoon55
Oct 15, 2005 01:22 AM
