Old May 28, 2021 | 07:05 PM
onehundred80
Default Re: opinions wanted please...
Originally Posted by Joe_Lukeman
I use a Deltran battery tender junior which is automatic but can only charge at a rate of 750 mA. I am so adverse to being stranded on the side of the road where there is no cell service I most likely will take the shot gun approach and take all suggested steps. I assume that if I change the battery every 4 years any AGM battery that fits will be ok. Any battery brands that I should avoid and any that I should favor?
Often batteries that are on sale are batteries that have sat on the shelf too long. Check the date on the side of the battery casing and check the label that says when it was last charged, that label can tell you if it has the original charge still or been recharged.
Make sure it comes with at least one plug, preferably two in the ends of the top part of the battery. They are in.vent holes, one goes to an overflow and the other is plugged to stop acid getting on your car.
