giaiu79
the mechanic tried to make current directly from the battery to the compressor and does not start the same. according to him he insists that the compressor is wrong. you think?
The clutch should engage and the compressor should run if you apply power to it. That does not mean you will get a lot of cold air, if the charge is not right or the engine fan is not pulling air across the condenser.
