Old Jul 23, 2021 | 09:39 AM
Doc78's Avatar
Doc78
Default Re: Dashboard lights
Originally Posted by Twinve
I have a 2004 coupe, it’s been sitting for awhile. Recently put a new battery in and the car runs great. There are two lights on the dash that were not illuminated before, the low tire pressure light and esp/ bas. Check tire pressure and it’s ok. Not sure what to do about other. I’m interested in any feedback. Thanks.
https://www.crossfireforum.org/forum...tml#post957514.
This is a good thread on the TMPS sensors and the aftermarket sensors that are way cheaper and how to program them.
When you do the all the way left and right then center procedure make sure the car is in the on position and not running. Then turn off wait two minutes and then start the car and drive a bit what I have read this should clear the code.
Is your wing out? Will your cruise control engage?
