Thread: Hesitation?
Old Jul 30, 2021 | 05:41 PM
GraphiteGhost
Default Re: Hesitation ?
Originally Posted by bc75
The cam position plug. The electric connection side of the sensor had oil in it. My car has 91,000 on it now.
Thanks for posting this additional information. There is a lot things that can be causing this given the additional information but I (again) do not believe this issue is corrected by a spring booster. You had a throttle body code and some indications of oil in the wiring. PLUS you swapped a lot of parts that didn't correct the issue. IF you become convinced that this might work (the booster), see if you can swap one in and are happy with it. I think you've thrown a lot of money at it already without success (and your the best judge of this). At this point, it could be a lot of little things, or one thing that hasn't been properly diagnosed. Where did that code come from (test equipment used)? IF it is a generic OBDII reader maybe someone with a better (more compatible) reader locally, can get a more in-depth reading? That's about all I can suggest, I hope more ppl can chime in with suggestions that par more with the change in performance your having. Good luck!
