Thread: Key fob
Old Aug 9, 2021 | 05:58 PM
onehundred80
Default Re: Key fob
Originally Posted by Sdawson789
I replaced the electronics on my broken key fob. My car will start but the lock and unlock panic buttons still do nothing. I've don everything on YouTube to try and program it to my car and nothing is working. Can somebody please help me..... 05 crossfire coupe
You say you have replaced the electronics, what did you replace? There is a little chip inside that only works on the car it was programmed for, obviously you kept that. Did you use the old circuit board or not?
People tend to damage the printed circuit board or a component on it when prying open the old case. The starting depends only on the little chip inside the case and the key fitting properly.
I suspect you have damaged the board or a component on it if you cannot program the fob.
