LGV-XFIRE
Ok guys, I'm having some real trouble here. I have the same issue (front driver turn signal/fast blink rear) with no bulb out indicator. I got the other housings and no joy. I tried bending out the connections and still nothing. Is it the headlight housing connection?
It is possible you will have to look inside the headlight preferably with a mirror and there might be a hole there where the turn signal socket makes contact. If that is the case then you need to remove the headlight and put some solder there to repair it.
