Old Sep 28, 2021 | 08:30 AM
dedwards0323
Default Re: Anybody know what this is?
Originally Posted by Mikey208
That's what it sounds like. I just wonder why the information in the odometer window didn't come up before. I think I have about 8.5 quarts in there. How did you siphon some out? I don't have anything that could do that.
Find a Lawn Mower oil siphon kit that comes with a long tube. Most lawn mowers nowadays require the oil to be siphoned out rather that drsined from the engine. Check the local Harbor Freight stores or
Amazon"><span style=Amazon" /> Amazon">Amazon
for one. Doesn't have to be motorized or anything fancy. You only need to remove 1/2 a quart. The one I have has tubing that is small enough to pass thru the oil dipstick tube to the oil sump. Otherwise, you will need to remove the oil filter housing (don't need to change the oil filter) & insert the siphon tube down thru the filter housing.
Since the HI Level alarm is only going off on a short section of road you drive everyday, and it's not alarming consistently as you drive the car elsewhere, I might not do anything until the next oil change. Then only put in 8 quarts during that oil change.
Later,
