Old Nov 27, 2021 | 10:43 PM
  #151 (permalink)
Buck62's Avatar
Buck62
Default Re: Standard, LED, and HID Lamp Solutions and Numbers
I use SliverStar Ultra's, very bright and both sets, less expensive than the one set of 'chip' bulbs you referenced. Since you didn't say what type you wanted, I thought you might consider these ( Set 1,Sylvania Silverstar ULTRA H7 Pair Set High Performance Headlight 2 Bulbs NEW | eBay & set 2, Sylvania Silverstar ULTRA H7 Pair Set High Performance Headlight 2 Bulbs NEW | eBay ). If you search for Silverstar Ultra H7 in ebay, there are a couple of twin or three packs as well (if buying from two sources for less $ isn't your thing). Good luck!
Thanks a bunch!
I did some looking around and the video below perfectly demonstrates the difference between OEM and the Silverstar Ultra bulbs for the headlights.
What about the high-beam and fog lights? Same bulbs?
And what do people use for those little upper corner lights?
Sorry to be such a PITA... but the Crossfire is totally new to me.
